swaping sector shafts in a PS box
remove pitman arm
remove 4 bolts on top of box
note position of adjuster
remove old sector shaft
instal new sector shaft and reverse procedure
dont forget to add fluid
at least thats how I did mine
The very first thing is the steering box needs to be centered or the sector shaft WILL NOT come out. Second, after you swap the shafts you MUST make a very critical adjustment (too loose and you have lots of play in the steering, too tight and you can't turn beyond center).
