My 700r4 blew up for the 2nd time in about a year. I can get ahold of a turbo 350 with the np 205 gear drive transfer case. I know i will need to change the shifter and probably the cross member, but i need to know if i can use the stock drive shafts from my 88 blazer, and also what will happen as far as the throttle body injection set up going from a 700r4 to a turbo 350? any help is appreciated. Thanks, Thomas
