3MAX
I've read several threads on removing the front swaybar, and there seems to be varying opinions as to how much it effects handling on the street.
I'd like to get thoughts from those that have done some towing with the swaybar removed. I'm in the middle of my build, and this Blazer will have 4" lift, 35" BFG's, 10 bolt front, 14 bolt semi-float rear, e-lockers, and 4.56 gears. It will be a daily driver, see quite a bit of towing with 4-5000 lbs, hunting, camping, and moderate trails.
I'm already replacing the steering box & ball joints, so if I'm going to do the crossover steering, now is the time.
Any thoughts, opinions are appreciated.
