4xcrazy
3/4 ton status
That's where I think the whole sway bar issue really comes into play, are the different spring rates and heights. I'm running a 4" Rough Country EZ ride lift, which I found out they switched all their current lifts over to this, I think that's why they got a bad rap several years back, they probably did ride rough. I personally don't think they ride as harsh as my buddys Pro Comp lift.
I also, in the past 2 years, have removed the lower leaf of the pack to kinda help with it's harshness at quick bumps, like speed bumps and such, smoothed it out quite a bit, it did lower just a tad, but nothing i'm worried about.
With this setup, if I don't have the sway bar hooked up, it's driveable, but there is a definate body roll feeling and overall squishy soft side to side swaying feeling in longer sweeping turns, corners and such. I personally prefer the bar hooked up. Which is why I run the discos, unhook them for trails, put em back on for the street. I haven't really been in too bad of spots with the 4" lift to warrant the expense and labor involved for crossover steering. Maybe if it was a more dedicated off road truck I would consider it more.
