Sway Bar
kgblazerfive
keymaster
Hooper, Utah 84315
Anybody running one with crossover steering?
Anybody running an aftermarket one?
Any other chioces other then Currie for aftermarket?
i had the same question, so i'll just tag along:D
usually everyone just takes them off? when you want flex why hinder it? just drive it like a lifted truck and not a sports car. as far as one in the rear, i only ever seen one on a blazer here.
Well my springs are real soft and it likes to body roll going down the street. Stiffer shocks would probably do the trick also but a sway bar would be better.
Yeah and if you make it so it (the sway bar) can be disconnected it won't hinder flex at all. Just give it better road manners.
You don't want a sway bar on the rear unless you have a bigger sway bar on the front.
