1990k5fan said:Hey mrk5, what are the yellow parts in the very front of your car for? Under the headlights in the last picture of your last post?
Colby posted a link to something similar that DIY4x sells, but his if for installing the longer 52" springs also. However, Kert will make one-off pieces so you may want to call and talk to him about making what you are looking for.jimmy1984 said:ya thats what i was asking about is there any place that i can buy those at and would those work with stock springs and just make it longer but not moved towards the front of the truck? would that be an ok way to lift the front a few inches? thanks for the reply also
You have to careful using something like that for too much lift. If you get carried away, it'll severely affect your caster angle. Plus adding 1" at one end or the either only equates to 1/2" of lift because you are only changing one end. Your best bet would be to add the same to both ends with longer shackles for the rear hanger.
If you're looking for like only 1", just do some ORD zero-rates.
