SYE kit HELP!!!
ClevelandCruiser
Portland, OR
Im installing my sye kit and it says to use a press to remove the bearings from the main sprocket is there any other way besides a press? its a 241
I never had to use a press. Are you talking about the two needle bearings that go next to each other on the main shaft under the synchro?
yes i was well i got those out but now im having the hardest time putting the new snap ring onto the new shaft to hold the main sprocket on....
