t-case help
bigboyblazers
ellinwood,ks
I have a 203 t-case. With the shifter in 4-hi or 4-lo and my hubs locked in I still only have 2wd. If I shift it to 4-hi lock or 4-lo lock I get a popping noise. Any help would be great. Thank you.
Put it in 4 wheel drive and then put the transmission in park. Then go underneath and try to spin the front drive shaft with the front hubs unlocked. If it does spin your transfer case is not going into four wheel drive and somehthing internal is broken, most likely a chain or shifter fork. If it does not spin, then you know that the drive shaft is at least connected to something, and it is either in the front diff or hubs, which are easy to pull off and check.
I think your chain may be stretched, and is jumping a tooth. I have the same problem. Go to the tech section on this site, and read the write-up on the Mile Marker part time kit by Grim Reaper. He addresses this somewhat. Mine only makes the popping when it's under load, albeit a very light load, if I'm just cruising in 4, it doesn't happen. Like I said, I think it's a stretched chain, for which 203's are notorious.
every owned a dirt bike? chains streatch like a Mo Fo. service life is determined by stretch. T-case would be similar IMO
