t-case options for doubler
1967k10
Nebraska looking for D60's
I see a mix and match on the ORD site. Can one use a Dodge 29spline 205 behind a GM 203?? Have a potential customer looking to build a rig and I have a GM 454/400/203 and a Dodge 205 and was hoping to help him out with the Dodge 205 since 32spline GM 205's have gotten expensive :(.
You can use the Dodge 205, you will just need to swap the 205 input to a 32 spline. We have the input shafts in stock.
correct me if i am wrong. but cant you use a ford 31 spline input also. ?
you might find one of them also.
This may be a little off but, I used a Dodge 203 and a Chevy 205. No problems with either. I just told them what I had and they sent every part I would need to get both under the truck. There really is no limit to what you can do with the doubler.
LT.
Well I have the Dodge 205 and I'm trying to save him some money. If he needs a 32spline input will it bolt right into the Dodge case without machining??
