buffblazer
ok first off i gotta have this fixed by 6 tomorrow night so if possible i need the quickest and most information i can get because i wont be able to get on much to check for updates
its a 1989 toyota camry, had a brake light out in the truck section of the lights. i pulled the bulb out of its holder and part of the bulb stayed with the connector
after that i lost all tail lights and blew the fuse for the running lights
i replaced the fuse and have running lights for the side markers and licence plate
i have brake lights, and flashers
no tail lights at all.
i isolated the two bulbs that were burnt up away from the rest of the wiring harness by disconnecting the wiring connector and it still didnt fix it.
any help would be great i checked the fuses in the engine bay and the fuses under the dash and all are ok.
Is there a fuse somewhere else that im missing or did i screw something up? the wiring on the car aint the best but heck the lights were working until i pulled the bulb
