Tailgate Lock Compatibility?
jeremywrags
Chino CA
Hi All,
I finally found a decent used power tailgate that is perfect except that the whole lock mechanism is missing.
OK I know that a Suburban tailgate wont work for the Blazer but will the locking mechanism work? The local Pick a Part has about 10 Suburbans with the Hardware but no Blazers.
Any help would be appreciated.
Jeremy
Which parts are you talking about?
Scott, some (only a few) parts are interchangable between the two surprisingly.
Im not sure what it is called but I need the chrome handle for the outside of the tailgate. I need one with a key to roll up and down the window.
Yes, that is the same, along with the inside handle and the little mechanism thingy that the inside handle pushes on.
I took a look through Classic Parts catalog and they show the Blazer and Burb as using the same tailgate roll up handle. I know that the window regulators are different between blazer and burb and if power window the motors are different as well.
Sweet, that is good to hear, I have all the internals and everything works perfectly I just need the external bezel and lock switch to operate the window.
Thanks for the replies.
