Tailgate rod
78K5BlazerTJ
Registered Member
Arizona
working on getting my tailgate to open, which was a nightmare. Anywho,
I had to manually pull the rods to disengage the latches which was not easy. this piece broke.
I can now, thankfully, open the tail gate but Id like to use the latch.
Mine is a manual open window. This piece keeps the driver side latch rod engaged in the opening mechanism.
Here is the piece Im after, I found nothing on LMC, partly because Im not even sure whay the part is called.
Tried a few home remedies but nothing works as the metal rod needs to move as the plastic keeps it mounted the opening device.
https://ibb.co/xq6Ppjs
That's called a "Jesus Clip" in the auto body business. Because when you accidentally break them or drop them down in the door, the words "Oh Jesus" often follow soon after.
