Snowman1000
Quick question would the tailgate off of a 1990 k5 fit on a 75 k5?
Are the internals (power window) interchangeable as well?? Thanks.
You are correct, the Sub tailgates are taller, glass is shorter, motor's are mounted directly to the regulator and don't use a cable, regulator's don't move as far, and even the external shape is different. The internal tailgate handle will interchange though.As long as we're talking Blazer tailgates only, not involving Suburbans, then yes, all the bits interchange nicely. I have a power tailgate with an '85 shell with '74 glass and '89 electrics and such.
Note that Suburban tailgates are different and IIRC neither the insides nor the glass are direct bolt-ups for Blazers.
-- A
The internal tailgate handle will interchange though.![]()
Oh yeah, I forgot that one. I unfortunately found out the hard way, much as it sounds like you did.But the damn access panel won't.![]()
