Talk to me about cranking torsion bars
hidesertwheelin
Hesperia, CA
The passanger side tire on wife's burb keeps hitting the bumper when turning hard. I crawled underneath, and the drivers side torsion bar is cranked all the way up, the passenger side is not. Can I just jack up the passenger side wheel and then hit the bolt on the torsion key with the impact? The tires are 285/75/16.
factory there never the same amount .
changing the bar / bolt position/length = re alignment time .
also turning up the bars = stiffer ride .
lots of ifs trucks with bigger tires from stock to lifted need bumper / fender / trimming done . I do it all the time on lift kits i install.
and for some reason gm has a problem with 1 side needs it a tweek more than the other side.
