badmix
Right now ive got a rough country 2" lift and 33s. They said their minimum is 4". Ive also got ORDs front HD shackles which raised the front 1/2" and if I get their rears, itll lower the back 1/2" or so. Ive got extended brake lines, but would it be necessary to do anything else? drop TC? Length Drive shafts? Im guessing the front would be 4.25" and the back would be 4" w/ORD HD shackles. COuld I run 35s with this setup?> Would my built 10bolt hold up? What are you guys' thoughts on this setup. Im wanting Pre runner ride height and bump soaking while sticking with leafs. They would still be cheaper than going with full on 4 link, etc.
