but cam is nothing if the heads won't support the flow. worse, if the cam is too large for the heads, it will run worse then it did with that stock cam. Flow on ramp heads - max, mind you, is something in the neighborhood of 135 cfm at max lift.... with a mild cam, 2 barrel tbi, and cast iron exhaust manifolds it is enough - but the moment you start doing anything to upset the cart, it's a waste of money.... conversely, if you leave the cam, leave the intake, leave the exhaust manifolds - you will get 50 plus hp by swapping to Vortec. Then change the cam, add headers, and put a BB TBI on it.... easy 125 net gain.
start with the heads.
and before you start about bolt pattern - you have 2 choices, either patriot heads that mimic the vortec chamber or vortec heads and redrill the holes... yeah, I know, the magazines get all snotty about it - funny thing the engine couldn't care less.
just as an aside, I've got a flow file that was done on both the vortec and the ramp heads because my wife needed them... and she used the theory behind those heads to create an inhaler for asthma patients that doesn't require an aerosol - to say I've way too much time in these designs would be an understatement.....
and I forgot about this - there was a year or so when the ramp heads were the latest thing for modifieds. If you ground the ramp out, the heads actually flowed really, really well.... just you had to grind the ramp out. The next year they allowed Vortecs and the ramps were relegated to the scrap heap.
