Yes, I'm aware of the VSS issues. However, I no longer even have the option of running a speedo due to the Ford/GM hybrid 205 case. The output shaft is Ford with the small gear and the tail housing is GM with the driven gear which does not make up with the smaller Ford drive gear. I'm told that there exists a driven gear that will work with the Ford output and GM output housing, but it (aparently) only exists in the rare late model 205s.
If anyone can verify that information (or provide years/part#?) then I would appreciate it...
Maybe someday I'll get it fixed, but it just isn't high on my priorites right now. I probably should have gone ahead and used my GM output just so I would have the speedo drive, but the Ford case was nearly new inside and I wanted to keep all the pieces together. Thanks for the warning though...
