TBI/EFI 454 system wanted
vtblazer said:
Have a Holley Pro-Jection.
4 barrel style.
this is not a complete system right??
i will still need an intake, oxegen senser and other stuff???
how much you want for it?
Complete from Holley, yes, ready to bolt on, no.
I was going to run it on a small block, here's what I have.
This set up is for something in the 400hp and up range.
$450.00 for the injection shipped within the states. ($550.00 with manifold)
how much do you estimate the weight of the whole package, including manifold??
which models of 454 engine would it fit on??
Price given is 'shipped' to your door, weight won't matter. ;)
Fits a standard bore manifold. (not spread bore)
i'm asking about the weight becaues i dont live in United states.. and if i buy it i will have it shipped to my US mail box which will have it forwarded to me... weight will then make a difference..
just give me an approximation weight..
:doah: sorry, just noticed your location. :doah:
I'll get right back to ya with the weight.
Everything pictured stuffed into in one box weighed 30 lbs.
Injection package and manifold.
any chance to get the part numbers for both the intake and the pro-jection
also can i see a pic of it installed on your engine... just want to see it
It's a Holley Street Dominator aluminum manifold.
701R-36 & 300-36 both #'s stamped on the underside.
Cast on 8/01/02.
# on the injection body is: 12R-11157B
Service # in the Holley manual is: 500-8
Closest one I have of it installed is of it sitting on the manifold.
Don't have one of it on a running engine.
Cast on 8/01/02.
the part number of the intake shows that this is for a small block engine.. wont fit on my 454 big block...
i'm trying to find info on the injected body...
would it fit on my standard intake??
As I posted earlier, I was going to run it on a small block, hence the Holley manifold fitting a small block, sorry for any confusion.
The injection set up is for a standard bore four barrel intake.
So yes, it will work on a big block that has a standard bore 4 barrel manifold.
Designed for engines having 300hp and up. (says this in the manual)
