tch777
I have seen the distributer re-curve kits from Accel and Flame thrower as well as the adjustable vaccum advance kits.
These sound easy enough to install if you can just get wedged in the back of the engine compartment to get to the HEI do these make a noticeable difference for the time and effort?
Next does upgrading the 4 pin ignition module really make much difference for a DD? Or is that more for a completely hopped up engine.
Just wondering as I am going to put a little bigger cam in with lifters and flow matched injectors to replace the factory ones with 134,000 on them but keep the cam tame enough that the computer will be happy. Also going to throw in a hotter coil.
I want to do headers too and a high flow cat into a 3 inch single exhaust with I think a Flowmaster muffler too.
Anything else I can do on the cheap to wake up the engine a little but not brake the bank?
I have a K&N air filter, a TBI spacer, a Turbo City velocity stack thingy on the factory air filter housing, and the injector pod spacer.
I have some ideas right now but if anyone has specific parts that worked great for them let me know that too.
Thanks
Tim
Thanks
Tim
