jteck10
got it, i'll do that today as wellinstall a pressure gauge (0 to 10psi) in the o2 sensor bung, warm up engine and cat, @2000 rpm you want less than 2.5 psi.
What transmission do you have?
If it's one of the "E" transmissions, check the Torque Converter lockup.
perfect, this is what i'll try today when i get some time - thanks!If the pump primes, the relay works, the ECM is commanding the relay to run the pump, pump is good, wiring to the pump is good. That doesn't mean there isn't an intermittent failure there somewhere, but the circuit does operate properly. You can start the truck and unplug the relay, if the oil pressure switch works and it keeps running, your problem almost certainly isn't the relay or the oil pressure switch since either one will keep it running until you turn the key off.
From the pic that ground looks great, often the entire area is rusted to hell. Pretty unlikely the ground is the issue, but can't make things worse. I like to hitstuff like thatevery electrical connection with dielectric grease when I reassemble.
4L60E, I don't remember what others have that torque converter lockup. If it stays in "lockup" when you come to a stop, it will stall the engine. Then disengage, as soon as you cycle the key off and on.
If it does turn out to be this, you can unplug the "lockup" plug and run without it, then fix it at you convenience.
Just my thoughts, as you've checked, and rechecked lots of the usual.
Let us know.
PS: this is one of the myriad of reasons I hate the "E" transmissions.
so this is a new one i havent heard yet.This would be anything with lockup, which includes the 700.
I forgot all about this as a potential issue, but either its not possible or exceedingly uncommon with the 700's.
If it's only stalling coming to a stop, I could see that being an issue. If it happens under steady throttle, I don't see that being the issue. That stalling issue occurs when the converter doesn't unlock and wants to continue to propel the vehicle forward. The act of using the brakes stalls the engine in that case.
At speed, momentum would prevent it from feeling like it stalled, as the engine would still turn, even if not firing.
finally had some time to get out and try theseIf the pump primes, the relay works, the ECM is commanding the relay to run the pump, pump is good, wiring to the pump is good. That doesn't mean there isn't an intermittent failure there somewhere, but the circuit does operate properly. You can start the truck and unplug the relay, if the oil pressure switch works and it keeps running, your problem almost certainly isn't the relay or the oil pressure switch since either one will keep it running until you turn the key off.
I put a 180 degree in my TBI truck one time, and It did not stop a my truck from running. It will cause the truck to go in and out of closed loop, which causes the OBDII/ECM to go bonkers with the fuel mixture, but that is about all.they were new.
wonder if the new tstat from 195 to 180 is messing that up?
so back to square oneI am not sure that's a valid test for the oil pressure sensor.
It is my understanding the oil pressure switch is there to shut the pump off if the engine stops running after an accident. So unplugging the sensor should shut the pump off
the shop i had i towed to replaced this ignition control module. when it shuts off, all my electrical stays on. dash lights and CEL comes on too.All it takes to damage one of these ignition modules, is a stray static discharge.
