TBI no fuel
Yea, I thought you meant you have used a noid light. The ignition module is inside the distributer. Just make sure to use the thermal grease when you replace it to avoid overheating it.
I was told it was called a pickup coil. Im gonna replace it tommorow, took out the distributor and disassembled it today. I figure I will clean it all up first. and Im glad you told me about the thermal grease because I would not of known.
Thank you very much,
-Frank
If you have the distributor out Replace both the pickup coil and the ignition module (black box with all the wires plugged into it.).
