TBI on 383?
best bet for you is go read www.tbichips .com info he has posted. tons of it and vary good. he gives the flow specs on a stock setup and it will not flow for your 383 worth a crap let alone stock 350 needs.
I think I emailed him earlier. Emailed a couple places.
got this :
The stock engine was 210 HP. The 383 should be 320>. The stock program and injectors only will run the 210 HP properly. The 383 will start and run but will be way down on power.
Quick fix- turn the fuel pressure up to 17-18 psi
Correct way is to use these parts
http://www.turbocity.com/product_info.php?cPath=16_27_28&products_id=700
I'm thinking it wouldn't be a good idea to run the 383 on the stock TBI.
