bp71k5
3/4 ton status
If you haven't been following my earlier threads, my issue now is that the engine pings under moderate to high engine load on 91 octane gas. No engine codes are being shown. My BLM data is now good with the higher fuel pressure according to TBIChips.
Brian at TBIchips is sending a new chip with a milder timing curve in an attempt to fix it.
Base timing is at 0.
I also want to drive this k5 1000 miles to moab in one week. If the pinging isn't gone, no moab.
Anyone have any options to get rid of my pinging if this new chip doesn't quite do it? Gas additives, fancy spark plugs, cooler thermostat, etc?
It's not a loud noise at all. I can't even hear it when the engine gets above 2500 rpm.
But after connecting it, no changes. I wonder why the ECM wasn't complaining about it not being hooked up and how could I get knock counts in winaldl with it disconnected?
