- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,077
No spark, no fuel. However when I took it apart it did dump a bunch of fuel because I didn't do the pull the plug disconnect the fuel pump thing. I didn't try to start it until the next day when it went clunk. I have checked for spark at #1 plug with a tester and on the coil to coil wire.
I fixed some wiring issues tonight and got solid 12 volts to the fuel pump again. I am checking out some wiring under the dash so haven't had a chance to try it again. I think I will pick up new plugs tomorrow, I already have new wires to put on anyway. Other things I have already done is new ignition module, new coil, new ignition switch in the dash, new computer under the dash GM 7747. I swapped the chip and prom if that is what they are called.
I will keep you posted. I tried to throw in the towel but my favorite local shop can't touch it for 3 weeks so guess I will be learning.
But even if you did, it should at least start and run poorly even if the computer was bad.
Thanks everybody for all the
