BlackBourbon
Buddys truck, 87 TBI. No injector spray when cranking but if you give it some fuel to start. both injectors spray fine. idles, drives, etc. just wont crank up again once shut off because lack of fuel for start
Remove the spark plug looking coil wire from the coil. Remove the longest spark plug wire from the distributor cap and spark plug. Plug one end of the longest spark plug wire to the ignition coil terminal (that normally goes to the distributor), and the other end to the spark plug. Usually the longest spark plug wire is long enough to position the spark plug somewhere that you can see if the spark plug "Sparks" when trying to start the engine. Now comes the jumper cable. The spark plug must be grounded to spark. I connect one end of the negative jumper cable to the spark plug, then I connect the other end of the negative jumper cable to the negative of the battery. Put both positive jumper cable ends in a safe place. A word of caution, don't hold the metal part of the the test spark plug when cranking the engine!!!!
X2I'm telling you, install a new module and i'll 99% guarantee your problem goes away. Worst case is the problem still exists and you now have a spare emergency back-up ignition module as they are a common failure point on any GM HEI ignition system.![]()
I'm telling you, install a new module and i'll 99% guarantee your problem goes away. .
