fulltilt
Registered Member
hay guys i got a 90 k5 and want to switch it over to carb but not sure about the electrical.
heres what i was thinking
go the the wrecking yard and get the entire engine electrical harness right to the fuse block from an older carbed truck
hook the fuel pump to 12v keyed and use a fuel pressure regulator and just plug off the return line
so will this work?
if not what how should i go about it
so will this work?
