I think so. I always double check with the VoM or test light@Bent77 Thanks for posting that pic. Your install looks clean.
@mrk5 , regarding the heavy pink vs pink/blk wire. It looks like both are ignition in the diagram. I was going to use the pink/blk since it was closer in size to the pf4 ignition wire (also pink/blk). Seems either wire should work correct?
I washed under the hood of the truck, I’ll get a picture here in just a bit@Bent77 Thanks for posting that pic. Your install looks clean.
Yes, I've used both@Bent77 Thanks for posting that pic. Your install looks clean.
2 thingsIf or when the 700r4 gives up, I’ll likely convert to an electronic controlled tranny and will need a second ignition wire.
Just to get cold clean air, less any water, I was thinking about using the stock air cleaner with the hose going to the core support vs open like on the car. In looking around for alternatives, I didn’t see any like you have on the truck pic, where the air cleaner was still on top of the intake. Do you feel you have enough filter surface?
I’m stuck on this charcoal canister vacuum source. As someone stated there is no ported vacuum on the pf4. No port in the water chamber to add a thermal activated ported vacuum switch.
The consensus, and as Wes noted, seems to be that vacuum before the throttle plate is considered to be ported. Seems to me this could be accomplished by adding a spacer between the throttle body and air cleaner and stick the vacuum line in the spacer. Or by simply tapping into the bottom of the air cleaner assembly, similar to mounting the air temp sensor for the pf4. This seems too easy to work. It also seems like someone would have already suggested this in one the many posts I’ve read on multiple forums.
I understand it might not be optimal. From what I’ve read the vacuum to the canister is only open until the engine warms up.
