DavidB
I know a few basics from TBI trouble over the last couple years, not enough. Posting to get some help and get all my thoughts together.
Thanks!
Working on my buddy's rock buggy.
Had a JY 350 when he bought it. Had/has rich/rough idle and stalling issues. Engine blew a HG, got a crate 350 from Summit - not a TBI engine, ordered the wrong one and got a carbed engine. Modified manifold bolt holes for TBI manifold....might have vacuum leak, didn't have any starting fluid to check for one. Anything else we should have done for the carb to TBI change? Cam?
Painless harness.
No VSS...OK?
New with new engine Holley ?670? TBI. Needs more fuel pressure?
Fuel Pressure is 11 right at the pump which I think might be low, but that's all the pump's got. Might try another. No regulator between pump and TBI, is there supposed to be one? Is there one in the TB itself???
http://www.cfm-tech.com/gm_tbi_fuel_pressure.htm
Thanks!
Painless harness.
No VSS...OK?
Trucks with 11-12 (or lower) psi will experience a drop in power, detonation, and/or drivability problems when any airflow inducing modification is made. Typically the product added is blamed, however, it is actually the lack of fuel that is the real problem! We can't stress how common this is!
Shorty headers and a hushpower muffler
Wow, lots of TBs from Holley. Looks like he replaced an earlier model 502-6 style with a later model 502-9. He said he had to do something to get the choke to hook up...? Wonder if it caused other issues? Maybe the ECM doesn't like it?
http://www.holley.com/types/Direct%20Replacement.asp
New distrib.
Single wire 02...probably going 3 or 4 wire. What's the diff 'tween 3 and 4?
Coolant temp sensor has been spliced in I think a yellow and orange wire. Blue wire was cut off...?I think that has some control related to the IAC's function. IAC looks like it's plunged all the way in to the TB all the time. IAC might need reset, I need some good inst. on how to do it.
Engine temp is controlled by fans w/ switches. I'm pretty sure TBI is pretty picky about temp. Should be 210 right? Probably need to get a thermo on there for the fans.
Timing Vac/light - didn't have a timing light so we tried to set it with a vac gauge. Can't get much more than 15" vacuum, and it bouces a few inches up and down....vac leak?
http://www.secondchancegarage.com/public/186.cfm
Come to think of it, I don't think there's a fuel filter on the stupid thing. Wonder if the new TBI got jacked up by some junk in the line from when it was all apart.....
Have a scanner but still learning to use it. I don't think we have any directions for it.
No EGR/Smog stuff. Off road only.
Is the third maybe for the factory temp gauge? Has a mech gauge on it now.
