DavidB
Are you saying park/neutral idle is ok, once put in gear it stalls, or that it stalls only when the throttle is applied?
I think it will idle around in 4lo but throttle or drive/reverse kill it. lack of VSS maybe?
The VSS is "off" according to the scanner.VSS has a huge bearing on idle for SOME ECM's. If you look at some posts in here for VSS, you'll see that many running the '747 ECM state that their setup doesn't care if it has VSS or not, while mine (which is TPI for the record) starts to have problems within miles of not getting VSS input.
Usually VSS is "turned off" in the PROM if its not going to be used, but Painless (a misnomer obviously) had/has simply had people ground the P/N switch to make the vehicle think it's always in park.
11psi could be too low. My 350 Scott built needs 18to run right
If the TPS was poofed, wouldn't that do it?
I suppose, but whatever happened to the low vacuum problem?
