Everyone on here seems to love the tbi so help me fix mine before I swap to a carburetor. Have a 1990 GMC Jimmy 5.7 350. When driving the service engine soon light is flashing pretty quickly. If I am running down the road it seems ok but when I come to a stop and idle like at a light it cuts off. Typically I can crank the key a few times and I get lucky and it starts or have to disconnect the battery, reconnect, then it runs. When I try an pull a code currently there is nothing. It was throwing codes which led to the maintaince below but now no codes.
So far in the past year I have done
- carquest T1830 whole distributor
- ac delco plugs
- ac delco wires
- bosch o2 sensor
- ac delco map sensor
- wire sleeved a lot of the mess around the intake
- replace a lot of the vacuum hoses
- made 1/0 battery cables (ground from battery to block & battery to frame)
- optima red
- napa gold fuel filter
- delphi fuel pump
Is it worth changing the tps sensor? I tried finding a mechanic to look at it but no one wants to touch the tbi. I am at wits end.
- ac delco plugs
- ac delco wires
- bosch o2 sensor
- optima red
- delphi fuel pump
