It has to be in cardboard, wood or metal to go overseas.
gmc4cw said:It has to be in cardboard, wood or metal to go overseas.
38377k5 said:Diagonal belted tires are probably radials. If you are interested in the difference between bias and radial tires, read here:
http://www.pirate4x4.com/articles/tech/billavista/PR-TSLs
Does anybody know how much air pressure is right for my K5? For street use.gmc4cw said:Looks like I am going to go buy some cheap ratchet straps. Or do you want good ones? It's your dime.
basically I prefer good quality rahter then cheap junk. But cheap does not always mean bad quality as expensive does not always mean good quality. However, since I planned to buy some ratchet straps to secure stuff on my roof rack and inside the truck I can use them anyway. I'm sure you know best what are good ones. Just saw some sets (4pcs) of 2" wide heavy duty ratched straps for less then $ 40,- so I leave it up to you. But if possible black or gray ones please
gmc4cw said:it's a good thing you picked a color. I buy the bright ones like yellow or light blue. It makes them easier to find. I'll see what I can find in 2".
