teflon
tecton
WV
would it be pratical to coat things on your truck with teflon to keep mud/dirt from adhereing?
chrome is so hard to keep clean
what about spray on? how does it do on paint or glass
Teflon has to be applied to metal in a very controlled process. You can't just spray it from a can and expect it to stick. /forums/images/graemlins/frown.gif It has to be heated to very high temps in order to bind with the underlying metal. The temp required is around 800 degrees F (thus the reason that pouring Teflon bits into an engine is a total waste of money).
Here's a link I found that talks a little bit about the process: Teflon coatings
