Tell me about Mini Starters?
KeyBlazer
Irvine, California
Working my way thru my k10 wilderness camper build, detailed elsewhere.
I have the old starter off, and boy is it a heavy lump.
As I’m also concerned about heat soak from the headers, I’m thinking it’s time for a mini starter…
I don’t know much about them or if they are better..
Something like this?
JEGS Heavy-Duty Mini Starter | Hitachi-Style | For Small Block and Big Block Chevy Engines | Made In USA https://a.co/d/fN2mmnz
Yeah, I’d never run the big brick again
Not sure on the brand, but that price is online with what I paid last time. Typically Jegs is good with customer service
Eileen's Corvette will not crank with a stock starter. Even a high torque stock style one. I bought the Summit version of that one. No big deal. And the headers are right there.
I second the Vortec starter. Twice the cranking power, 1/2 the weight, less current draw, and the solenoid can be rotated so you can get to that pesky start terminal. Also aren't affected by header heat as bad.
damn you are tempting me to jump on board... nothing wrong with the one in my truck, buuuuut that all sounds nice. have to swap motors soon, and that thing is definitely a "heavy lump"!
That makes my life easy. Engine I’m putting in my blazer is a 97 vortec block.
Haven’t got the headers in that side of the motor yet. Not too tight, I don’t think but I’ve had headers and heat soak issues with my 454 powered Motorhome before, so wary.
Ordered that Jegs unit.
$123 seems good to me, and ordered one of those heat wrap shields too.
Will report back when it arrives.
Here's mine in all it's crusty glory. Starter was given to me, formerly used on a circle track car. Battery cable is in poor shape. Headers are fairly close. Thing starts without issue in sub-freezing weather, or after towing steep hills in 90* weather, and has for 5+ years. Turns over far easier than it ever did with a "new" parts store starter. And so much easier to deal with, in all regards...weight, access, clearance, etc.
full
Good stuff.
Pulled my old one off yesterday. I swear it weighs 100lb.
Did a quick test fit of rh headers… looks fine…
I’m in Ca(for now) so heat is gonna be an issue. Need to rewire that whole area as I see all the wires are toast.
If you are going to rewire, I recommend the 2 relay system. wire like this.
left is factory style right is how I did mine. 4ga is minimum.
Good info.
My wiring harness in the engine bay is pretty ragged.
Prob need to redo it all...
Anyone bought a new harness and installed... maybe I need to start a dedicated thread, but where?
I can tell you from experience that the remote solenoid can cause some "run-on" of the permanent magnet starters. It does it on my '72.
Good to know. I had heard it does on the GM ls starters. Wasn't sure if the jegs would be the same.
I am old school, I have a copper armature starter, and no headers.
Wired like that for 3 years now. No cranking issues, with a good battery. Even had a crappy PO spliced multi ga crank signal wire till recently
