andyblack
Registered Loser
Hello everyone. I used to be on this forum a few years ago but then they blocked this site on my computer at work, I couldn't add it to Tapatalk on my phone... yack yack blah blah.
Anyway I'm back to annoy you all with a question. I have an '85 truck. I took out the original 305 a few years back and put in a 350 from a '72 El Camino. When I did the swap, I used the sensor or sending unit or whatever from the '72 350 because the one from the '85 was about twice as big in diameter and wouldn't fit in the block. Anyway, now the temp gauge only registers the coolant temp when the ignition is switched off. That's right. The gauge reads 0 degrees until I stop the truck and turn the key to off; then the needle will go up to 195 or whatever. This has caused me to overheat once and I don't want it to happen again. So my question is, is there an adapter or something that will make the '85 gauge work with the '72 sending unit? The gauge worked perfectly before the swap. Or do I need a gauge that will work with the '72 sending unit? The electrical plug was the same btw.
