Thank GOODNESS I didn't have this problem while in Moab. It's not fun loosing steering and brakes.
Just had the truck out today at the local mud hole. Everything was great. Drive about a mile on rocky dirt to the exit. Then drove another ~6 miles out of the mountain through a twisty road. Come up to the first stop light and it dies.
I get it fired back up but it wont idle, so I do the whole brake pedal and gas pedal at once thing all the way home ~14 miles
I get home and notice while parking (and trying to keep it running) that I'm blowing major black smoke. I pop the hood and have my brother take a look at the fuel pump pressure gauge. It should be ~44 psi. It will run 44psi while it's choking at idle. To keep it from dying, I bring it up to ~1200rpm and which point it's controllable, but the fuel pressure is ~34psi. That's weird.
I had an idling problem before and found it was the Walbro pump taking a dump. But it never blew black smoke and would run at 10-20psi and fluctuate wildly, no mater the rpm.
I parked the truck for tonight. I'll deal with it another day. This is a FAST EZ EFI system and I'll be calling them later, see what they think. I noticed my computer light isn't on while the ignition is "KEYED ON". It is only on while running. I don't think it should be like that, so I'm lost there. It's not blinking, so there's no codes.
Once off idle, truck does fine. Performed great today too, climbed all I wanted and managed to RIP OFF TWO DIFFERENT JEEPS' BUMPERS
and break my yacht braid rope 3 times
EDIT from later post:
other then this how does it perform? Easy to tune?
