So what I gather from this thread is that Luke's favorite EFI is FAST, because of their excellent prices and poor ground compatability?
Seriously though, FAST was the first to come out with a self tuning system that works well with high pressure injectors below the throttle blades, most systems will be susceptible to poor grounds, but I am sure some are more sensitive than others. It doesn't have a lot of tuneability or ignition control (the EZ 2.0 is improved), however, that is not what it was designed for, it was designed to be extremely simple but work, and it is. Tuning time spent is literally a couple minutes and it does the rest itself. Now other companies have followed suit and you have more self tuning options.
Ignition control is nice, but it really doesn't give you much benefit when you have to phase the rotor and spend time setting that up. Unless you go DIS like you did, then it's definitely more worth it. But EZ 2.0 has ignition control, and you can add it to the EZ with a $300 MSD box, so it's not really that big of a deal, I can't justfiy spending the $300 on my truck because I already had an MSD box and once the timing curve is adjusted there is no need to touch it anymore.
If you want extreme adjustability then the XFI will leave the factory stuff in the dust. However, these days I would rather have Big Stuff 3 or a Holley Dominator system because they can control DIS coil packs, injectors, and a GM trans all with one computer box. FAST still requires seperate boxes for all of those, so they are in need of an upgrade. But all of those fully programmable systems will leave the factory stuff behind when it comes to racing controls and custom capabilities.
I am sure you got your system working for much cheaper than $2k, I applaud you for that, it's impressive to convert your engine over to DIS. I don't have the patience to build electronics, I would rather spend it fabbing stuff or tuning the engine.
