so we were all sitting around after i cut down my mag. runflats and got the idea to see if or how flamable this stuff is...here is how it went
1.swept up all the dust into a pile and hit it with a mapp gas torch...some small white sparks no fire though
2.added water (supposobly if you add water it becomes more flamable) notthing at all no sparks nothing
3.got a nother pile and sprayed carb cleaner to get it to burn,nothing happened but when we tried to put the fire with your foot more white sparks,no fire though
4.heat the hell out of the pile and then we had an intence bright light with the same white sparks (looked like a sparkler ) but no flames
5.last but not least we took the leftover runflat and try to catch it on fire nothiing happened...sprayed it in carb cleaner still nothing....
here is my conclusion
i think you could cut the runflats down with a plasma cutter or a torch and be fine...do i want to be the one to find out sure dont....
i would say the myth is plausible with magnesium alloy but could deffinitley be confirmed with pure magnesium
