Old trucks need work. Just did a complete frame off on my dad's 77 bronco. Only thing original is the engine block, axle housings, and transfer case housing. Speedometer keeps shorting out, had a short in the front turn signal, carb was misadjusted and float bowl damaged at some point, coil had gotten cracked and was shorting, looks like the rear main seal has started to weep (probably from being installed 3 years ago and not run until recently), rear u-bolts came loose. Get the picture? There is ALWAYS something to tinker on these old trucks. Always.
But don't get discouraged. That's half the fun of these rigs is working on them. Just buy or rent tools as needed.
