JKK-71K5
Registered Member
Hello guys,
I have a 71 K5 that I converted the trans from the 350 to 700R4. I have the stock tilt column and would like to get the neutral safety switch correct. This is for obvious reasons, but I all ready had it start on me in drive and luckily I was in the garage, it only moved 2 feet and bent the bumper...
Anyway, the stock one will not adjust for both the neutral/safety and turn on the rear lights as I would expect... Does anyone know of a later model switch that will bolt in to accomodate for the change from 3 to 4 speeds and the added detent?
I still need to change the indicator lens as well...
