th350/208 to sm465/205 swap
Pelahatchie, Mississippi
Im planning to do the swap above. The original trans was a 700r or whatever but was swapped to a th350. Now im swapping to a sm465/205. Question is what kind problems/mods am i going to run into? Will the existing driveshafts, crossmember, etc still work with this combo? Im also doing a 10b to 14b swap at the same time. Will this just be a bolt in swap?:confused:
swap swap swap....
I just did the same swap except the 14B, I have a 3 inch body lift which made the it a lil harder. Hopefully u have the brake/clutch peddle assembly and the bracket that bolts to the frame. it's a direct bolt in, crossmember is the same, except I had to enlarge one of the bolt holes on the xmember. you will have to change your driveshafts. I had to lenghten the front and I had a driveshaft from a long bed pickup that I had shorten, I also had to enlarge the hole in the floor pan for the clutch rod cuz of the body lift. Good luck its a bad a$$ combo
