Rebuilt the box with a TCI pro super kit. Drove fine at first. Started to drive it a bit harder through the gears after about 10 miles. Not flooring it but giving it a bit more sort of normal use. Without warning I lose forward gears. Still have P R and N working as normal. After about 20 mins if i put it in 1 it sort of rattles a bit when I gas it then tries to lurch backwards momentarily like it's dropping in to reverse. The selecter mech is all fine externally.
The kick down cable had stuck open(extended)Problem?? Made no diff pushing it back.
Also, I had a leak from the dipstick tube-I broke the o ring when fitting it. When I replaced it today it looked like some of the o ring is missing. But if this had dropped into the pan surely it wouldn't do any harm as it can't get past the filter screen.
Any ideas greatly appreciated. I am not happy! /forums/images/graemlins/angryfire.gif Wanted more than 10 miles out of a tranny rebuild!! /forums/images/graemlins/doah.gif
OK!!! Dropped the pan and found some sludge a few tiny bits of metal. But at the top of the casing on the outside, just rear of the bellhousing on the left there is a 1/2 inch whole that has leaked oil. It looks loike there should be a core plug or something there but I can see into the trans (I think!) What should be there??/what blew it out...or maybe I should say why as I know high pressure must have blown it out! /forums/images/graemlins/confused.gif
