Ok I've driven this newly rebuilt trans with the rv torque converter a couple months back but after oil leaks and what sounded like a cracked flex plate I parked it in disgust n threw my tantrum.
After a couple months I resealed a bunch of stuff and decided to shake it down once again but now it's not goin into reverse to get out of the shop. Nothing at all other than a ratcheting when put back in park. As if it were still rolling. I'm gonna perform a psi test tomorrow but the noise I was hearing leads me to think this t/c is bad. Just poking around to see if anyone here has had any issue similar. I'd like to figure it out before I just bolt the stock converter back in bc that thing hooked fine n threw the axles/d shaft in the swamp. Flex plate is good. Bolts are tight. 383stroker 505lbft Hughes GM11XTM T350 30sp 3pd HD TOW. Fresh rebuild on the th350 professionally. Thanks guys
