Hello I have a 79 blazer with a 350/350/np203. This thing pours out fluid. It appears to be coming from the top where the trans and transfer case meet. What should I do to fix this or what are common leaks that look like they come from there. And I found my crossmember on the 203 very loosely mounted. And on the inside of the adapter plate where it bolts to the trans those four bolts very loose. Could that have something to do with it? Thanks
