I have a question/problem. My tranny has been releasing fluid out the filler tube. At first I thought it was overheating, then today I discovered exactly when it was doing it. This is the second time this happened. The truck was parked all day, so I know it was no hot. I backed the truck up to the garage door,(approx. 45 ft), and shut it off. I went inside to get a jack. I then proceeded to jack the right rear tire off the ground, that's when I heard fluid hitting the ground. I lokked under to see a steady stream flowing on the ground. It was so much that I had time to walk around the truck to release the hood from inside the cab, oopen the hood, and verify that "Yep" it is definitely coming out the top of the filler tube.
I have never seen this before. The truck was not hot, nor was it running at the time. It did, however, put a lot of fluid on the ground.
Does anyone have an idea of what may be wrong? Should I be looking for a different Tranny?
Thanks for you help.
To prevent it from happening again, you could run a small rubber hose from that vent outlet up high into the engine compartment or something to keep the vent line clear and so no water/mud could get in there.
