dixiechevy01
I have a th400 with a np208 t-case behind it in my k5, both output seals on the t-case are leaking and I'm probably gonna be raplacing them soon. The transmission takes a little bit of fluid every once in a while so I was thinking maybe the front t-case and rear trans seal might be going out, so I checked the t-case fluid and it wasn't even up to the fill plug. Does anyone know the proper level for the 208 and what type of fluid to use in it?
Also does anyone know if there is way to rebuild the front driveshaft slip joint or do you just have to replace the whole driveshaft?
