TH400 deep aluminum transmission pan and TransGo kit questions
Zeus33rd
Smarter than you
Grass Valley, CA
I'm eyeballin one of these along with a TransGo 400-1-2 kit on Summit.
Specifically, this pan- http://www.summitracing.com/parts/TCI-228000/
And this kit- http://www.summitracing.com/parts/TRG-400-1-2/
The pan offers +2qt capacity, drain plug etc. But no temp sending unit bung. How do you add one to these aftermarket aluminum pans? Is it as simple as drilling a hole and TIG'ing on the bung?
As for the kit. Does anyone run one of these? What can you say about it's manners? Reading this thread on Pirate- http://www.pirate4x4.com/forum/showthread.php?t=890898&highlight=th400+transgo has taught me a lot, but not much in the way of street manners. I don't want neck snappingly firm shifts, but I don't want it to feel like a cadilac either.
Those pans are the sheeit. Any deeper pan is great as long as it includes the filter extension, and i see that that one does. Personally id drill and tap the hole for a sending unit, the pans are thick enough and there is no pressure occuring in the pan. As for the shift kit, i havent personally installed one into a 400 , but on 700's and 4L60-e's, and various other manufactures trans' . Transgo is top notch, and the kit will likely provide options for fine tuning or tailoring the shift to your liking.
drill & tap hole 1/8 pipe thread most sendors.
and transgo = top notch. not to hard on tranny but firms up all the weak points good.
I dunno why it didn't occur to me to drill and tap. Duh. :whistle:
I guess I need to go find a gauge and sending unit now. I love Summit. :bow:
Transgo makes great products. As far as the pan, if you are playing on the rocks either protect it or go with a steel pan. I smacked the front of mine on a rock and dented it pretty good and if it was a aluminum pan I would have probably shattered it.
Ok, another $350 goes screaming out of the bank account. Picked up the 400-1-2 kit, the TCI deep pan, a filter kit and this gauge-
http://www.summitracing.com/parts/ATM-6949/
I like the digital gauges over the standard ones, easier to read at a glance.
I wish I could see the stack of parts waiting for me....it must be ginormous. :eek1:
No rocks for this truck. It's goin on my street queen V3500 dually.
Hmm....Unless you think I could find a curb that would reach the tranny pan with a rig on 39's? Maybe a loading dock/ramp? :haha:
I have a nice deep aluminum pan (B&M one) for my trucks TH400,but I have not installed it because I heard its supposed to have a filter extention peice..so far I have not seen anyplace listing one separately..had it riding around in the trucks toolbox for years now,would like to use it ..anyone know where to get the right extention separately?..
I would say get a hold of B&M. I'm thinkin they'd send you one.
I was just on B&M's website and the filter extension IS sold seperately by them and it is part number 20271. http://www.bmracing.com/PRODUCTS/Transmission-Pans_2/Filter-Extension_2
Thanks for that info--I'll have to get one so I can put that deeper pan on it before winter sets in..been meaning to change the fluid in it for 6 years now..it only plows my driveway and makes short trips so I'm sure it could use a fluid & filter change..trans was supposedly rebuilt just before I got the truck..
Now,if I can olny get the rear u-bolts & spring plates on it,replace ALL the brake lines,master cylinder,oil cooler hoses,wheel cylinders and rubber brake hoses,maybe I can actually USE this truck again without fear of roadside failures..:doah:
