TH400 info
slyguy_22
Lancaster, PA
Ok i have a TH400 trans out of a 2wheel drive. What all is involved to use it in a 4x4 application? is it just a matter of swapping output shafts or is it more involved than that?
Search is your friend. Loose the tailhousing & swap the shafts. Swapping the shaft requires a complete tear down.
Or do what I did. Got a 208/241 adaptor, 2" thick spacer, short input off early 205 case. My spacer is for a Ford 205 case, but no reason a GM one can't be used....
It all depends on what t-case you're using. A 2wd 400 with a short tail bolt on yoke will fit a pre-'85 (figure 8 pattern) 205 set up (w/ short 32 spline input, of course). Other t-case configurations will require a tailshaft change.
