GsxrMike
What needs to be done to swap a 205 in place of a 208 on a TH400 if I have the 205 and adaptor from a TH400?
You need to have the correct lenth output on the 400 for the input in your 205.The 400's used 3-4 different output's,and maybe a crossmember depending on what adapter your using.
If it being to long was the only problem couldn't I cut the output shaft and file the end?
, its to short. i seen in my other post i said it was to long, doh
You can also change the input of the 205 to a long input if it is not already. check this site, there is alot of info and they helped me over the phone even tho I was never a customer(yet).You need to have the correct lenth output on the 400 for the input in your 205.The 400's used 3-4 different output's,and maybe a crossmember depending on what adapter your using.
