TH700R4
Mikedohc
Good morning companions! I am writing to ask you where I can find a service and repair manual, to rebuild the manual gearbox th700r4 MD8 4x4 in Spanish, because with English I do not understand technically well. I await comments, thank you very much!
I have to rebuild it, although I have just completely repaired it, but it gives a lot of pull from first to second, and the reverse gear, sometimes it slips.
I have tried to find a new one, that they can send me to Spain, but it is very expensive
BEst reguards
First make sure you're fluid level is correct. If the engine/transmission is up to operating temperature, the fluid should be up past the bottom dot on the dipstick and at least halfway up the part with the Xs on it. One time I didn't have enough fluid in mine and it would do okay in the forward gears but would slip in reverse.
