Thanks to CK5,and DIY4x and a few pics of my truck
ahhhaa didnt notice the perch I was just looking at the bleeder. Good point the calipers need to be roatated 90*
i have not tried to bleed yet but the calipers are mounted so they sit exactly in the position the front sit at why would i need to move?:confused:
divorced said:
Look how the spring perch sits in relation to the bleeder screw. When the axle is in the truck, the bleeder looks like it will be horizontal, pointing to either the front or rear of the rig.
if you look closely the the spring perch is what is holding the axle on the concrete blocks, when the axle is sitting flush with the suspension the caliper will be closer to 45 degrees it will be almost exactly where it sits stock on the 10 bolt front?:confused:
Brocky said:
Looking good. Is that a hole in the back for sending unit access. I cut holes in all my rigs for this. Good job so far.
yep i hate having to drop gas tanks so i built a 12" x 12" access panel into the subframe
your right i looked at it today after rotating the axle and it is straight up and down i thought i had put it one notch to the rear because the diy bracket has 8 mounting holes to move around i will try it first and if i have any issues i will rotate it
